Variable expression levels detected in the Drosophila effectors of piRNA biogenesis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Gene Année : 2014
piRNAs (piwi-interacting RNAs) are a class of small interfering RNAs that play a major role in the regulation of transposable elements (TEs) in Drosophila and are considered of fundamental importance in gonadal development. Genes encoding the effectors of the piRNA machinery are thus often though to be highly constrained. On the contrary, as actors of genetic immunity, these genes have also been shown to evolve rapidly and display a high level of sequence variability. In order to assess the support for these competing models, we analyzed seven genes of the piRNA pathway using a collection of wild-type strains of Drosophila simulans, which are known to display significant variability in their TE content between strains. We showed that these genes exhibited wide variation in transcript levels, and we discuss some evolutionary considerations regarding the observed variability in TE copy numbers.
Fablet_08nov2013.pdf (350.96 Ko) Télécharger le fichier
hal-00922704 , version 1 (30-05-2017)
Marie Fablet, Abdou Akkouche, Virginie Braman, Cristina Vieira. Variable expression levels detected in the Drosophila effectors of piRNA biogenesis. Gene, 2014, 537 (1), pp.149-153. ⟨10.1016/j.gene.2013.11.095⟩. ⟨hal-00922704⟩
185 Consultations
284 Téléchargements
