Adaptive Feedforward Compensation Algorithms for Active Vibration Control with Mechanical Coupling and Local Feedback - a unified approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport Année : 2014
Adaptive feedforward broadband vibration (or noise) compensation is currently used when a correlated measurement with the disturbance (an image of the disturbance) is available. Most of the active vibration control systems feature an internal "positive" mechanical feedback between the compensation system and the reference source (a correlated measurement with the disturbance). Such systems have often also a feedback control loop for reducing the effect of disturbances. Therefore the adaptive feedforward compensation algorithms should take into account this structure. For stability reasons the adaptation algorithms requires the implementation of a filter on observed data or a filtering of the residual acceleration in order to satisfy some passivity conditions. The paper proposes new algorithms for the adaptive feedforward compensation in this context with both filtering of data and of the residual acceleration and using an "Integral + Proportional" (IP) adaptation as a means for accelerating the transients as well as for relaxing the positive real conditions required by the stability analysis. The paper also shows that the main interest in filtering the residual acceleration is to shape in the frequency domain the power spectral density (PSD) of the residual acceleration. The algorithms have been applied to an active vibration control (AVC) system and real time results illustrating the advantages of the proposed algorithms are presented.
note_interne.pdf (1.27 Mo) Télécharger le fichier
hal-00922912 , version 1 (31-12-2013)
hal-00922912 , version 2 (09-01-2014)
  • HAL Id : hal-00922912 , version 2
Ioan Doré Landau, Tudor-Bogdan Airimitoaie, Marouane Alma. Adaptive Feedforward Compensation Algorithms for Active Vibration Control with Mechanical Coupling and Local Feedback - a unified approach. 2014. ⟨hal-00922912v2⟩
760 Consultations
529 Téléchargements
