TRINITY: An IDE For The Matrix - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2013
Digital forensics software often has to be changed to cope with new variants and versions of file formats. Developers reverse engineer the actual files, and then change the source code of the analysis tools. This process is error-prone and time consuming because the relation between the newly encountered data and how the source code must be changed is implicit. TRINITY is an integrated debugging environment which makes this relation explicit using the DERRIC DSL for describing file formats. TRINITY consists of three simultaneous views: 1) the runtime state of an analysis, 2) a hex view of the actual data, and 3) the file format description. Cross-view trace ability links allow developers to better understand how the file format description should be modified. TRINITY aims to make the process of adapting digital forensics software more effective and efficient.
No file
Dates and versions
hal-00923400 , version 1 (02-01-2014)
Identifiers
Cite
Jeroen van den Bos, Tijs van Der Storm. TRINITY: An IDE For The Matrix. ICSM 2013 - 29th IEEE International Conference on Software Maintenance, Sep 2013, Eindhoven, Netherlands. pp.520-523, ⟨10.1109/ICSM.2013.86⟩. ⟨hal-00923400⟩
Collections
INRIA INRIA2
34 View
0 Download
Share
