LORIA System for the WMT13 Quality Estimation Shared Task - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper we present the system we submitted to the WMT13 shared task on Quality Estimation. We participated to the Task 1.1. Each translated sentence is given a score between 0 and 1. The score is obtained by using several numerical or boolean features calculated according to the source and target sentences. We perform a linear regression of the feature space against scores in the range [0..1], to this end, we use a Support Vector Machine with 66 features. In this paper, we propose to increase the size of the training corpus. For that, we decide to use the post-edited and reference corpora in the training step after assigning a score to each sentence of these corpora. Then, we tune these scores on a development corpus. This leads to an improvement of 10.5% on the development corpus, in terms of Mean Average Error, but achieves only a sligth improvement on the test corpus.
wmt2013_langlois_smaili_preprint.pdf (154.81 Ko) Télécharger le fichier
hal-00923623 , version 1 (15-11-2017)
  • HAL Id : hal-00923623 , version 1
David Langlois, Kamel Smaïli. LORIA System for the WMT13 Quality Estimation Shared Task. ACL 2013 - Eighth Workshop on Statistical Machine Translation, Aug 2013, Sofia, Bulgaria. pp.380 - 385. ⟨hal-00923623⟩
111 Consultations
100 Téléchargements
