Impulsive observer-based control for linear systems using irregularly sampled measurements - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
In this paper, we consider the issue of stabilizing a class of linear systems using irregular sampled output measurements. For this purpose, we design a standard linear state feedback controller and an impulsive observer to provide an estimate the non-measured states, which are subsequently fedback in the control algorithm. We consider linear systems thatcan be decomposed, via a change of coordinates, into their respective measured and unmeasured dynamics. We consider the two cases whereby the unmeasured subspace is stable and unstable respectively. In the case where the unmeasured subspace is stable, we employ a standard impulsive observer coupled with a continuous linear feedback control. Next, when the unmeasured subspace is unstable, we employ two cascaded observers - an impulsive and a Luenberger observer - in conjunction with a linear feedback control. In order to prove the stability of the overall closed-loop system we proposed a practical stability result for a class of linear impulsive systems. Some simulation results are presented to show the performance of the observer-based control. Finally, some conclusions are drawn.
Africon2013_sent.pdf (223.52 Ko) Télécharger le fichier
hal-00923640 , version 1 (03-01-2014)
  • HAL Id : hal-00923640 , version 1
Yassine Khaled, Jean-Pierre Barbot, Krishna Busawon, Djamila Benmerzouk. Impulsive observer-based control for linear systems using irregularly sampled measurements. IEEE AFRICON 2013, Sep 2013, Mauritius, Mauritius. ⟨hal-00923640⟩
666 Consultations
404 Téléchargements
