A passivity-based controller for coordination of converters in a fuel cell system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Control Engineering Practice Année : 2013
The problem of converters coordination of a fuel cell system involving a hydrogen fuel cell with super-capacitors for applications with high instantaneous dynamic power is addressed in this paper. The problem is solved by using a non-linear controller based on passivity. The controller design is based on the interconnection and damping assignment approach, where the proof of the local system stability of the whole closed-loop system is shown. Simulation and experimental results on a reduced scale system prove the feasibility of the proposed approach for a real electrical vehicle.
RI12_APassivityBasedControllerForCoordinationOfConvertersInAFCS_HAL.pdf (1.51 Mo) Télécharger le fichier
hal-00923716 , version 1 (03-01-2014)
hal-00923716 , version 2 (02-03-2019)
M. Hilairet, M Ghanes, O. Béthoux, V Tanasa, J-P Barbot, et al.. A passivity-based controller for coordination of converters in a fuel cell system. Control Engineering Practice, 2013, 21 (8), pp.1097 - 1109. ⟨10.1016/j.conengprac.2013.04.003⟩. ⟨hal-00923716v2⟩
490 Consultations
1126 Téléchargements
