Distributed dictionary learning over a sensor network - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We consider the problem of distributed dictionary learning, where a set of nodes is required to collec- tively learn a common dictionary from noisy measure- ments. This approach may be useful in several con- texts including sensor networks. Diffusion cooperation schemes have been proposed to solve the distributed linear regression problem. In this work we focus on a diffusion-based adaptive dictionary learning strategy: each node records observations and cooperates with its neighbors by sharing its local dictionary. The resulting algorithm corresponds to a distributed block coordi- nate descent (alternate optimization). Beyond dictio- nary learning, this strategy could be adapted to many matrix factorization problems and generalized to var- ious settings. This article presents our approach and illustrates its efficiency on some numerical examples.
distrib_dico_learning_cap2013_final.pdf (288.29 Ko) Télécharger le fichier
hal-00923741 , version 1 (04-01-2014)
  • HAL Id : hal-00923741 , version 1
Pierre Chainais, Cédric Richard. Distributed dictionary learning over a sensor network. CaP 2013, Jul 2013, Villeneuve d'Ascq, France. pp.1-4. ⟨hal-00923741⟩
325 Consultations
203 Téléchargements
