High-Order Time Discretization Of The Wave Equation By Nabla-P Scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès ESAIM: Proceedings Année : 2014
High-order Discontinuous Galerkin Methods (DGM) are now routinely used for simulation of wave propagation, especially for geophysic applications. However, to fully take advantage of the high-order space discretization, it is relevant to use a high-order time discretization. Hence, DGM are classicaly coupled with ADER schemes, which leads to high-order explicit time schemes, but requires the introduction of auxiliary unknowns. The memory can thus be considerably cluttered up. In this work, we propose a new high order time scheme, the so-called Nabla-p scheme. This scheme does not increase the storage costs since it is a single step method which does not require the storage of auxiliary unknowns. Numerical results show that it requires less storage and less computational costs than the DG-ADER scheme for a given accuracy.
Fichier non déposé
hal-00924030 , version 1 (06-01-2014)
  • HAL Id : hal-00924030 , version 1
Hélène Barucq, Julien Diaz, Florent Ventimiglia, Henri Calandra. High-Order Time Discretization Of The Wave Equation By Nabla-P Scheme. SMAI 2013, May 2013, Seignosse, France. pp.ESAIM: PROCEEDINGS. ⟨hal-00924030⟩
273 Consultations
0 Téléchargements
