Ancillary service to the grid from deferrable loads: the case for intelligent pool pumps in Florida - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Renewable energy sources such as wind and solar power have a high degree of unpredictability and time-variation, which makes balancing demand and supply challenging. One possible way to address this challenge is to harness the inherent flexibility in demand of many types of loads. We focus on pool pumps, and how they can be used to provide ancillary service to the grid for maintaining demand-supply balance. A Markovian Decision Process (MDP) model is introduced for an individual pool pump. A randomized control architecture is proposed, motivated by the need for decentralized decision making, and the need to avoid synchronization that can lead to large and detrimental spikes in demand. An aggregate model for a large number of pools is then developed by examining the mean field limit. A key innovation is an LTI-system approximation of the aggregate nonlinear model, with a scalar signal as the input and a measure of the aggregate demand as the output. This makes the approximation particularly convenient for control design at the grid level. Simulations are provided to illustrate the accuracy of the approximations and effectiveness of the proposed control approach.
Fichier non déposé
hal-00924315 , version 1 (06-01-2014)
  • HAL Id : hal-00924315 , version 1
Sean Meyn, Prabir Barooah, Ana Bušić, Jordan Ehren. Ancillary service to the grid from deferrable loads: the case for intelligent pool pumps in Florida. CDC 2013 - 52st IEEE Conference on Decision and Control, Dec 2013, Florence, Italy. pp.n/a. ⟨hal-00924315⟩
186 Consultations
0 Téléchargements
