A Collaborative Framework for Non-Linear Integer Arithmetic Reasoning in Alt-Ergo
In this paper, we describe a collaborative framework for reasoning modulo simple properties of non-linear integer arithmetic. This framework relies on the AC(X) combination method and on interval calculus. The first component is used to handle equalities of linear integer arithmetic and associativity and commutativity properties of non-linear multiplication. The interval calculus component is used - in addition to standard linear operations over inequalities - to refine bounds of non-linear terms and to inform the SAT solver about judicious case-splits on bounded intervals. The framework has been implemented in the Alt-Ergo theorem prover. We show its effectiveness on a set of formulas generated from deductive program verification.
Logique en informatique [cs.LO]
