Inverse reinforcement learning to control a robotic arm using a Brain-Computer Interface - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2012
The goal of this project is to use inverse reinforce- ment learning to better control a JACO robotic arm developed by Kinova in a Brain-Computer Interface (BCI). A self-paced BCI such as a motor imagery based-BCI allows the subject to give orders at any time to freely control a device. But using this paradigm, even after a long training, the accuracy of the classifier used to recognize the order is not 100%. While a lot of studies try to improve the accuracy using a preprocessing stage that improves the feature extraction, we work on a post- processing solution. The classifier used to recognize the mental commands will provide as outputs a value for each command such as the posterior probability. But the executed action will not only depend on this information. A decision process will also take into account the position of the robotic arm and previous trajectories. More precisely, the decision process will be obtained applying an inverse reinforcement learning (IRL) on a subset of trajectories specified by an expert. At the end of the workshop, the convergence of the inverse reinforcement algorithm has not been achieved. Nevertheless, we developed a whole processing chain based on OpenViBE for controlling 2D- movements and we present how to deal with this high dimensional time series problem with a lot of noise which is unusual for the IRL community.
eINTERFACE12-ArmBand-report.pdf (425.9 Ko) Télécharger le fichier
hal-00924653 , version 1 (07-01-2014)
  • HAL Id : hal-00924653 , version 1
Laurent Bougrain, Matthieu Duvinage, Edouard Klein. Inverse reinforcement learning to control a robotic arm using a Brain-Computer Interface. [Research Report] 2012. ⟨hal-00924653⟩
738 Consultations
863 Téléchargements
