Design and implementation of compact diplexers using dual-mode cavities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of RF and Microwave Computer-Aided Engineering Année : 2014
Hussein Ezzeddine
  • Fonction : Auteur
  • PersonId : 919484
Kamel Frigui
  • Fonction : Auteur
  • PersonId : 919491
Stéphane Bila
Serge Verdeyme
  • Fonction : Auteur
  • PersonId : 915587
In this paper, the design of compact diplexers with dual-mode cavities for satellite payloads is detailed. Compact diplexers are composed of coupled resonators without additional waveguide element, leading to a more compact architecture. Two topologies are first implemented and compared with a standard manifold output diplexer, in terms of electrical performances, compactness, and power handling. Hardware prototypes are fabricated and measured for experimental verification. A third topology is finally introduced for the design of noncontiguous diplexers.
Electronique
hal-00924828 , version 1 (07-01-2014)
Hussein Ezzeddine, Kamel Frigui, Stéphane Bila, Serge Verdeyme, Fabien Seyfert, et al.. Design and implementation of compact diplexers using dual-mode cavities. International Journal of RF and Microwave Computer-Aided Engineering, 2014, 24 (2), pp.249-258. ⟨10.1002/mmce.20760⟩. ⟨hal-00924828⟩
333 Consultations
0 Téléchargements
