Unconventional and Nested Computations in Spatial Computing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal of Unconventional Computing Année : 2013
Modern programming languages allow the definition and the use of arbitrary nested data structures but this is not generally considered in unconventional programming models. In this paper, we present arbitrary nested topological collections in MGS, a spatial computing language. By considering different classes of neighborhood relationships, MGS can emulate several unconventional computing models from a programming point of view. The use of arbitrary nested spatial structures allows a hierarchical form of coupling between them. Furthermore, we propose an extension of the MGS pattern-matching facilities to handle nesting explicitly. This makes possible the emulation of a larger class of uncon- ventional programming models.
Fichier non déposé
hal-00925718 , version 1 (08-01-2014)
  • HAL Id : hal-00925718 , version 1
Jean-Louis Giavitto, Olivier Michel, Antoine Spicher. Unconventional and Nested Computations in Spatial Computing. International Journal of Unconventional Computing, 2013, 9 (1-2), pp.71-95. ⟨hal-00925718⟩
190 Consultations
0 Téléchargements
