An Autonomic and Scalable Management System for Private Clouds - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Snooze is an open-source scalable, autonomic, and energy-efficient virtual machine (VM) management framework for private clouds. It allows users to build compute infrastructures from virtualized resources. Particularly, once installed and configured, it allows its users to submit and control the life-cycle of a large number of VMs. For scalability, the system relies on a self-organizing hierarchical architecture. Moreover, it implements self-healing mechanisms in case of failure to enable high availability. It also performs energy efficient distributed VM management through consolidation and power management techniques. This poster focuses on the experimental validation of two main properties of Snooze: scalability and fault-tolerance.
Fichier non déposé
hal-00925726 , version 1 (08-01-2014)
  • HAL Id : hal-00925726 , version 1
Matthieu Simonin, Eugen Feller, Anne-Cécile Orgerie, Yvon Jégou, Christine Morin. An Autonomic and Scalable Management System for Private Clouds. The 13th IEEE/ACM International Symposium on Cluster, Cloud and Grid Computing (CCGrid), May 2013, Delft, Netherlands. ⟨hal-00925726⟩
377 Consultations
0 Téléchargements
