Computation and Visualization of Musical Structures in Chord-Based Simplicial Complexes - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We represent chord collections by simplicial complexes. A temporal organization of the chords corresponds to a path in the com- plex. A set of n-note chords equivalent up to transposition and inversion is represented by a complex related by its 1-skeleton to a generalized Ton- netz. Complexes are computed with MGS, a spatial computing language, and analyzed and visualized in Hexachord, a computer-aided music anal- ysis environment. We introduce the notion of compliance, a measure of the ability of a chord-based simplicial complex to represent a musical object compactly. Some examples illustrate the use of this notion to characterize musical pieces and styles.
bigo-et-al_mcm2013.pdf (1.53 Mo) Télécharger le fichier
hal-00925748 , version 1 (11-06-2020)
Louis Bigo, Jean-Louis Giavitto, Moreno Andreatta, Olivier Michel, Antoine Spicher. Computation and Visualization of Musical Structures in Chord-Based Simplicial Complexes. MCM 2013 - 4th International Conference Mathematics and Computation in Music, Jun 2013, Montreal, Canada. pp.38-51, ⟨10.1007/978-3-642-39357-0_3⟩. ⟨hal-00925748⟩
387 Consultations
317 Téléchargements
