The expected total cost criterion for Markov decision processes under constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Applied Probability Année : 2013
In this work, we study discrete-time Markov decision processes (MDPs) with constraints when all the objectives have the same form of expected total cost over the infinite time horizon. Our objective is to analyze this problem by using the linear programming approach. Under some technical hypotheses, it is shown that if there exists an optimal solution for the associated linear program then there exists a randomized stationary policy which is optimal for the MDP, and that the optimal value of the linear program coincides with the optimal value of the constrained control problem. A second important result states that the set of randomized stationary policies provides a sufficient set for solving this MDP. It is important to note that, in contrast with the classical results of the literature, we do not assume the MDP to be transient or absorbing. More importantly, we do not impose the cost functions to be nonnegative or to be bounded below. Several examples are presented to illustrate our results.
hal-00925859 , version 1 (08-01-2014)
François Dufour, Alexei Piunovskiy. The expected total cost criterion for Markov decision processes under constraints. Advances in Applied Probability, 2013, 45 (3), pp.837-859. ⟨10.1017/S0001867800006601⟩. ⟨hal-00925859⟩
78 Consultations
0 Téléchargements
