Interaction−Based Modeling of Morphogenesis in MGS - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2013
In this chapter, we advocate a domain specific language (DSL) approach to overcome the difficulties of modeling and simulating morphogenetic processes. A careful discussion of the design goals of a DSL leads to the development of an ex- perimental programming language called MGS. Its declarative approach is based on the notion of topological collection originating from algebraic topology. Topologi- cal collections arise naturally when modeling a "dynamical system with a dynamic structure", or (DS)2, as the state of the system. The evolution function of the system is specified by a transformation, which is a set of rewriting rules where each rule defines a local interaction. We illustrate these notions through different models of the same morphogenetic process: the growth of a T-shaped structure. The objective is to show how a variety of models can be consistently handled within the MGS framework.
hal-00925879 , version 1 (08-01-2014)
Jean-Louis Giavitto, Olivier Michel, Antoine Spicher. Interaction−Based Modeling of Morphogenesis in MGS. R. Doursat and H. Sayama. Morphogenetic Engineering, Springer, pp.409-440, 2013, Understanding Complex Systems, 978-3-642-33901-1. ⟨10.1007/978-3-642-33902-8_16⟩. ⟨hal-00925879⟩
142 Consultations
0 Téléchargements
