Simulation-based Verification of Hybrid Automata Stochastic Logic Formulas for Stochastic Symmetric Nets - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The Hybrid Automata Stochastic Logic (HASL) has been recently defined as a flexible way to express classical performance measures as well as more complex, path-based ones (generically called "HASL formulas"). The considered paths are executions of Generalized Stochastic Petri Nets (GSPN), which are an extension of the basic Petri net formalism to define discrete event stochastic processes. The computation of the HASL formulas for a GSPN model is demanded to the COSMOS tool, that applies simulation techniques to the formula computation. Stochastic Symmetric Nets (SSN) are a high level Petri net formalism, of the colored type, in which tokens can have an identity, and it is well known that colored Petri nets allow one to describe systems in a more compact and parametric form than basic (uncolored) Petri nets. In this paper we propose to extend HASL and COSMOS to support colors, so that performance formulas for SSN can be easily defined and evaluated. This requires a new definition of the logic, to ensure that colors are taken into account in a correct and useful manner, and a significant extension of the COSMOS tool.
Fichier non déposé
hal-00926210 , version 1 (09-01-2014)
Elvio Gilberto Amparore, Benoît Barbot, Marco Beccuti, Susanna Donatelli, Giuliana Franceschinis. Simulation-based Verification of Hybrid Automata Stochastic Logic Formulas for Stochastic Symmetric Nets. 1st ACM SIGSIM Conference on Principles of Advanced Discrete Simulation (PADS'13), 2013, Canada. pp.253-264, ⟨10.1145/2486092.2486124⟩. ⟨hal-00926210⟩
75 Consultations
0 Téléchargements
