Numerical modeling of the electrical activity of the atria and the pulmonary veins - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Poster Année : 2013
Three axes are explored. 1) Derivation of mathematical models. Mathematical methods allow to derive simplified models from three-dimensional complex ones, while controlling approximation errors. We construct a bilayer surface model that allows to simulate three-dimensional phenomena for a bi-dimensional computational load, to investigate 3D atrial patterns such that electrical dissociation or transmural heterogeneities. Those methods are also used to construct a homogenized model that includes the non linear behavior of gap junctions. 2) Triggers of atrial arrhythmia. Proofs of concept of arrhythmogenic mechanisms are given by using numerical models of the pulmonary veins. The first mechanism is based on a unidirectional conduction block triggered by a discontinuity of the fibre distribution. The second one comes from a different propagation pattern during the depolarization and the repolarization when two layer of fibres are superimposed. 3)Atrial arrhythmia perpetuation. We investigate the influence of transmural heterogeneities of the distribution of fibrosis on the perpetuation of atrial arrhythmia. Several ablation protocols are assessed. Finally, a method of personalization of the model is given.
Le travail présenté s'articule en trois axes distincts. 1)Dérivation de modèles mathématiques. Des méthodes mathématiques permettent de dériver des modèles simplifiés à partir de modèles tridimensionnels complexes, tout en contrôlant l'erreur d'approximation. Ces méthodes ont permis de dériver un modèle bisurfacique qui permet de simuler des phénomènes tridimensionnels dans les oreillettes pour un coût numérique bidimensionnel afin d'étudier des phénomènes tels que la dissociation électrique ou des hétérogénéités transmurales. Ces méthodes sont également utilisées pour construire un modèle homogénéisé incluant le comportement non linéaire des gap junctions. 2) Processus déclencheurs d'arythmie. Des preuves de concepts de mécanismes arythmogènes sont apportées à l'aide de modèles numériques des veines pulmonaires. Le premier mécanisme repose sur un bloc de conduction unidirectionnel engendré par une discontinuité dans la structure fibreuse. Le second est basé sur une dynamique différente à la dépolarisation et à la repolarisation lors de la superposition de deux couches de fibres. 3) Perpétuation des arythmies auriculaires. A partir d'un modèle bicouche des oreillettes, nous étudions l'influence d'hétérogénéités transmurales de fibrose sur la perpétuation des arythmies. De plus, plusieurs protocoles d'ablation sont testés. Enfin, une méthode de personnalisation du modèle est formalisée.
poster-ihu.pdf (3.09 Mo) Télécharger le fichier
hal-00926441 , version 1 (09-01-2014)
  • HAL Id : hal-00926441 , version 1
Simon Labarthe, Yves Coudière, Jacques Henry. Numerical modeling of the electrical activity of the atria and the pulmonary veins. Workshop IHU Liryc, Oct 2013, Pessac, France. ⟨hal-00926441⟩
163 Consultations
89 Téléchargements
