A probabilistic interpretation of the parametrix method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue The Annals of Applied Probability Année : 2015
In this article, we introduce the parametrix method for constructions of fundamental solutions as a general method based on semigroups and difference of generators. This leads to a probabilistic interpretation of the parametrix method that are amenable to Monte Carlo simulation. We consider the explicit examples of continuous diffusions and jump driven stochastic differential equations with Ho ̈lder continuous coefficients.
BallyKohatzu20140109.pdf (494.95 Ko) Télécharger le fichier
hal-00926479 , version 1 (23-01-2014)
Vlad Bally, Arturo Kohatsu-Higa. A probabilistic interpretation of the parametrix method. The Annals of Applied Probability, 2015, 25, pp.3095-3138. ⟨10.1214/14-AAP1068⟩. ⟨hal-00926479⟩
483 Consultations
412 Téléchargements
