Data-based filtering for replicated high-throughput transcriptome sequencing experiments
RNA sequencing is now widely performed to study differential expression among experimental conditions. As tests are performed on a large number of genes, very stringent false discovery rate control is required at the expense of detection power. Ad hoc filtering techniques are regularly used to moderate this correction by removing genes with low signal, with little attention paid to their impact on downstream analyses.
