Pressure-velocity coupling for unsteady low Mach number flow simulations: An improvement of the AUSM + -up scheme - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational and Applied Mathematics Année : 2013
The proper scaling of the pressure-velocity coupling that arises from the momentum interpolation approach for unsteady calculation in low Mach number flow is first identified. Then, it is used to suggest a modification of the AUSM +-up scheme that allows acoustic simulations in low Mach number flow.
jcam_2013.pdf (231.94 Ko) Télécharger le fichier
hal-02359034 , version 1 (13-11-2019)
Yann Moguen, Erik Dick, Jan Vierendeels, Pascal Bruel. Pressure-velocity coupling for unsteady low Mach number flow simulations: An improvement of the AUSM + -up scheme. Journal of Computational and Applied Mathematics, 2013, 246, pp.136 - 143. ⟨10.1016/j.cam.2012.10.029⟩. ⟨hal-02359034⟩
213 Consultations
104 Téléchargements
