Modeling of the oxygen transfer in the respiratory process - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ESAIM: Mathematical Modelling and Numerical Analysis Année : 2013
In this article, we propose an integrated model for oxygen transfer into the blood, coupled with a lumped mechanical model for the ventilation process. We aim at investigating oxygen transfer into the blood at rest or exercise. The first task consists in describing nonlinear effects of the oxygen transfer under normal conditions. We also include the possible diffusion limitation in oxygen transfer observed in extreme regimes involving parameters such as alveolar and venous blood oxygen partial pressures, capillary volume, diffusing capacity of the membrane, oxygen binding by hemoglobin and transit time of the red blood cells in the capillaries. The second task consists in discussing the oxygen concentration heterogeneity along the path length in the acinus
DiffO2.pp.pdf (309.13 Ko) Télécharger le fichier
hal-00714239 , version 1 (03-07-2012)
hal-00714239 , version 2 (16-01-2014)
Sébastien Martin, Bertrand Maury. Modeling of the oxygen transfer in the respiratory process. ESAIM: Mathematical Modelling and Numerical Analysis, 2013, 47 (04), pp.935-960. ⟨10.1051/m2an/2012052⟩. ⟨hal-00714239v2⟩
1236 Consultations
3581 Téléchargements
