Robust and efficient preconditioned Krylov spectral solvers for computing the ground states of fast rotating and strongly interacting Bose-Einstein condensates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2014
We consider the Backward Euler SPectral (BESP) scheme proposed in [10] for computing the stationary states of Bose-Einstein Condensates (BECs) through the Gross-Pitaevskii equation. We show that the fixed point approach introduced in [10] fails to converge for fast rotating BECs. A simple alternative approach based on Krylov subspace solvers with a Laplace or Thomas-Fermi preconditioner is given. Numerical simulations (obtained with the associated freely available Matlab toolbox GPELab) for complex configurations show that the method is accurate, fast and robust for 2D/3D problems and multi-components BECs.
PKrylovGPERevised.pdf (988.87 Ko) Télécharger le fichier
hal-00931117 , version 1 (14-01-2014)
Xavier Antoine, Romain Duboscq. Robust and efficient preconditioned Krylov spectral solvers for computing the ground states of fast rotating and strongly interacting Bose-Einstein condensates. Journal of Computational Physics, 2014, 258 (1), pp.509-523. ⟨10.1016/j.jcp.2013.10.045⟩. ⟨hal-00931117⟩
334 Consultations
311 Téléchargements
