Hydrascope: Creating Multi-Surface Meta-Applications Through View Synchronization and Input Multiplexing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Björn Hartmann
  • Fonction : Auteur
  • PersonId : 945897
BiD
Wendy E. Mackay
As computing environments that combine multiple displays and input devices become more common, the need for applications that take advantage of these capabilities becomes more pressing. However, few applications are designed to support such multi-surface environments. We investigate how to adapt existing applications without access to their source code. We introduce HydraScope, a framework for transforming existing web applications into meta-applications that execute and synchronize multiple copies of applications in parallel, with a multi-user input layer for interacting with it. We describe the Hydra-Scope architecture, validated with five meta-applications.
hartmann.pdf (1018.44 Ko) Télécharger le fichier
hal-00931142 , version 1 (15-01-2014)
Björn Hartmann, Michel Beaudouin-Lafon, Wendy E. Mackay. Hydrascope: Creating Multi-Surface Meta-Applications Through View Synchronization and Input Multiplexing. 2nd ACM International Symposium on Pervasive Displays, Jun 2013, Mountain View, United States. pp.43-48, ⟨10.1145/2491568.2491578⟩. ⟨hal-00931142⟩
557 Consultations
410 Téléchargements
