Traveling wave solution of the Hele-Shaw model of tumor growth with nutrient - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 2014
Several mathematical models of tumor growth are now commonly used to explain medical observations and predict cancer evolution based on images. These models incorporate mechanical laws for tissue compression combined with rules for nutrients availability which can differ depending on the situation under consideration, in vivo or in vitro. Numerical solutions exhibit, as expected from medical observations, a proliferative rim and a necrotic core. However, their precise profiles are rather complex, both in one and two dimensions.
TW_Heleshaw_Jan_14.pdf (836.62 Ko) Télécharger le fichier
hal-00931399 , version 1 (15-01-2014)
Benoît Perthame, Min Tang, Nicolas Vauchelet. Traveling wave solution of the Hele-Shaw model of tumor growth with nutrient. Mathematical Models and Methods in Applied Sciences, 2014, 24 (13), pp.2601-2626. ⟨hal-00931399⟩
904 Consultations
1272 Téléchargements
