Hamiltonian splitting for the Vlasov-Maxwell equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Computational Physics Année : 2015
A new splitting is proposed for solving the Vlasov--Maxwell system. This splitting is based on a decomposition of the Hamiltonian of the Vlasov--Maxwell system and allows for the construction of arbitrary high order methods by composition (independent of the specific deterministic method used for the discretization of the phase space). Moreover, we show that for a spectral method in space this scheme satisfies Poisson's equation without explicitly solving it. Finally, we present some examples in the context of the time evolution of an electromagnetic plasma instability which emphasizes the excellent behavior of the new splitting compared to methods from the literature.
cef-vlasovmaxwell.pdf (777.22 Ko) Télécharger le fichier
hal-00932122 , version 1 (16-01-2014)
Nicolas Crouseilles, Lukas Einkemmer, Erwan Faou. Hamiltonian splitting for the Vlasov-Maxwell equations. Journal of Computational Physics, 2015, 283, pp.224-240. ⟨10.1016/j.jcp.2014.11.029⟩. ⟨hal-00932122⟩
400 Consultations
549 Téléchargements
