A New Interface Cement Equilibrated Mortar (NICEM) method with Robin interface conditions: the P1 finite element case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 2013
We design and analyze a new non-conforming domain decomposition method, named the NICEM method, based on Schwarz type approaches that allows for the use of Robin interface conditions on non-conforming grids. The method is proven to be well posed. The error analysis is performed in 2D and in 3D for P1 elements. Numerical results in 2D illustrate the new method.
Fichier non déposé
hal-00933608 , version 1 (20-01-2014)
Caroline Japhet, Yvon Maday, Frédéric Nataf. A New Interface Cement Equilibrated Mortar (NICEM) method with Robin interface conditions: the P1 finite element case. Mathematical Models and Methods in Applied Sciences, 2013, 23 (12), pp.2253-2292. ⟨10.1142/S0218202513500310⟩. ⟨hal-00933608⟩
162 Consultations
0 Téléchargements
