Preliminary Study of Rib Articulated Model based on Dynamic Fluoroscopy Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
We present in this paper a preliminary study of rib motion tracking during Interventional Radiology (IR) fluoroscopy guided procedures. It consists in providing a physician with moving rib three-dimensional (3D) models projected in the fluoroscopy plane during a treatment. The strategy is to help to quickly recognize the target and the no-go areas i.e. the tumor and the organs to avoid. The method consists in i) elaborating a kinematic model of each rib from a preoperative computerized tomography (CT) scan, ii) processing the on-line fluoroscopy image and iii) optimizing the parameters of the kinematic law such as the transformed 3D rib projected on the medical image plane fit well with the previously processed image. The results show a visually good rib tracking that has been quantitatively validated by showing a periodic motion as well as a good synchronism between ribs.
spie2014.pdf (12.94 Mo) Télécharger le fichier
Format : Figure, Image
hal-00933638 , version 1 (20-02-2014)
Pierre-Frédéric Villard, Pierre Escamilla, Erwan Kerrien, Sébastien Gorges, Yves Trousset, et al.. Preliminary Study of Rib Articulated Model based on Dynamic Fluoroscopy Images. SPIE Medical Imaging, Feb 2014, San Diego, United Kingdom. pp.90361Y, ⟨10.1117/12.2043003⟩. ⟨hal-00933638⟩
491 Consultations
174 Téléchargements
