Hierarchy of consistent n-component Cahn-Hilliard systems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Mathematical Models and Methods in Applied Sciences Année : 2014
In this paper, we propose a new generalization of the well-known Cahn-Hilliard two-phase model for the modelling of n-phase mixtures. The model is derived using the consistency principle: we require that our n-phase model exactly coincide with the classical two-phase model when only two phases are present in the system. We give conditions for the model to be well-posed. We also present numerical results (including simulations obtained when coupling the Cahn-Hilliard system with the Navier-Stokes so as to obtain a phase-field model for multiphase flows) to illustre the capability of such modelling.
BM_14.pdf (1.42 Mo) Télécharger le fichier
hal-00933674 , version 1 (20-01-2014)
Franck Boyer, Sebastian Minjeaud. Hierarchy of consistent n-component Cahn-Hilliard systems. Mathematical Models and Methods in Applied Sciences, 2014, 24 (14), pp.2885-2928. ⟨10.1142/S0218202514500407⟩. ⟨hal-00933674⟩
402 Consultations
521 Téléchargements
