Dynamic Countermeasure Against the Zero Power Analysis - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2013
Elliptic Curve Cryptography can be vulnerable to Side-Channel Attacks, such as the Zero Power Analysis (ZPA). This attack takes advantage of the occurrence of special points that bring a zero-value when computing a doubling or an addition of points. This paper consists in analysing this attack. Some properties of the said special points are explicited. A novel dynamic countermeasure is described . The elliptic curve formulæ are up dated depending on the elliptic curve and the provided base point.
Fichier non déposé
hal-00934336 , version 1 (21-01-2014)
  • HAL Id : hal-00934336 , version 1
Jean-Luc Danger, Sylvain Guilley, Philippe Hoogvorst, Cédric Murdica, David Naccache. Dynamic Countermeasure Against the Zero Power Analysis. [Research Report] IACR Cryptology ePrint Archive 2013: 764 (2013), 2013. ⟨hal-00934336⟩
358 Consultations
0 Téléchargements
