Value of spontaneous hyperdensity of cerebral venous thrombosis on helical CT - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Acta Radiologica Année : 2013
BACKGROUND: Excluding a cerebral venous thrombosis (CVT) through imaging is a frequent request in the emergency setting. This assessment often starts by an unenhanced brain computed tomography (CT). PURPOSE: Re-evaluate the value of spontaneous hyperdensity of CVT on helical unenhanced brain CT. METHODS: Multicentric retrospective study on CVT probability based on visual assessment of spontaneous hyperdensity of cerebral venous system, performed by four blinded radiologists, individually then collectively, on a population including 14 helical unenhanced brain CTs with CVT and 102 unenhanced brain CTs without CVT (all confirmed by CT or magnetic resonance [MR] venography). Exclusion criteria: no DICOM image, symptoms >15 days, CVT indirect signs on unenhanced CT. A fifth radiologist set 768 regions of interest to measure and to compare the density within the normal venous sinuses and the CVTs. RESULTS: After consensus reading, sensitivity of this sign for CVT diagnosis was 100%, specificity 95.1%, and negative predictive value (NPV) 100%, with high individual NPV (99-100%). Area under the receiver-operating characteristic curve was 0.992 after consensus (0.976-0.986 individually). The spontaneous density was significantly different (P <0.05) between normal sinuses and CVTs, with a density >70 HU reported only within the CVTs, except for the horizontal part of the superior sagittal sinus (hSSS). CONCLUSION: The dense triangle sign on helical unenhanced brain CT has an excellent NPV to exclude a sinus thrombosis during the first 2 weeks. However, we believe that visual assessment of spontaneous hyperdensity is not sufficient for the diagnosis of CVT, with possible false-positive of the hSSS on unenhanced CT.
Fichier non déposé
hal-00934623 , version 1 (22-01-2014)
Marc Garetier, Jean Rousset, Ernesto Pearson, Valentin Tissot, Jean-Christophe Gentric, et al.. Value of spontaneous hyperdensity of cerebral venous thrombosis on helical CT. Acta Radiologica, 2013, epub ahead of print. ⟨10.1177/0284185113513977⟩. ⟨hal-00934623⟩
410 Consultations
0 Téléchargements
