Equivalence conditions between linear Lagrangian finite element and node-centred finite volume schemes for conservation laws in cylindrical coordinates - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue International Journal for Numerical Methods in Fluids Année : 2014
A complete set of equivalence conditions, relating the mass-lumped Bubnov-Galerkin finite element (FE) scheme for Lagrangian linear elements to node-centred finite volume (FV) schemes, is derived for the first time for conservation laws in a three-dimensional cylindrical reference. Equivalence conditions are used to devise a class of FV schemes, in which all grid-dependent quantities are defined in terms of FE integrals. Moreover, all relevant differential operators in the FV framework are consistent with their FE counterparts, thus opening the way to the development of consistent hybrid FV/FE schemes for conservation laws in a three-dimensional cylindrical coordinate system. The two-dimensional schemes for the polar and the axisymmetrical cases are also explicitly derived. Numerical experiments for compressible unsteady flows, including expanding and converging shock problems and the interaction of a converging shock waves with obstacles, are carried out using the new approach. The results agree fairly well with one-dimensional simulations and simplified models.
output.pdf (2.51 Mo) Télécharger le fichier
hal-00935561 , version 1 (23-01-2014)
Dante de Santis, Gianluca Geraci, Alberto Guardone. Equivalence conditions between linear Lagrangian finite element and node-centred finite volume schemes for conservation laws in cylindrical coordinates. International Journal for Numerical Methods in Fluids, 2014, 74 (7), pp.514-542. ⟨10.1002/fld.3862⟩. ⟨hal-00935561⟩
147 Consultations
185 Téléchargements
