A numerical study of two dimensional flows past a bluff body for dilute polymer solutions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Non-Newtonian Fluid Mechanics Année : 2013
In this paper, we use a simple Oldroyd B constitutive model to study the role of the viscoelasticity of dilute polymer solutions in two-dimensional flows past a bluff body using numerical simulations. This investigation is motivated by the numerous experimental results obtained in quasi two dimensional systems such as soap film channels. The numerical modeling is novel for this case and therefore a comprehensive comparison is carried out to validate the present penalization method and artificial boundary conditions. In particular we focus on flow past a circular object for various values of the Reynolds number, Weissenberg number, and polymer viscosity ratio. Drag enhancement and drag reduction regimes are discussed in detail along with their flow features such as the pattern of vortex-shedding, the variation of lift as well as changes in pressure, elongational rates, and polymer stress profiles. A comprehensive study of the flow behavior and energy balance are carefully carried out for high Reynolds numbers. Flow instabilities in both numerical and experimental results are discussed for high Weissenberg numbers
XiongJNNFM2013_Postprint.pdf (4.84 Mo) Télécharger le fichier
hal-00935690 , version 1 (15-12-2017)
Paternité - Pas d'utilisation commerciale - Pas de modification
Yong Liang Xiong, Charles-Henri Bruneau, Hamid Kellay. A numerical study of two dimensional flows past a bluff body for dilute polymer solutions. Journal of Non-Newtonian Fluid Mechanics, 2013, 196, pp.8-26. ⟨10.1016/j.jnnfm.2012.12.003⟩. ⟨hal-00935690⟩
340 Consultations
254 Téléchargements
