Generic hyperbolicity of Aubry sets on surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Inventiones Mathematicae Année : 2015
Given a Tonelli Hamiltonian of class C2 on the cotangent bundle of a compact surface, we show that there is an open dense set of potentials in the C2 topology for which the Aubry set is hyperbolic in its energy level.
CFR.pdf (428.83 Ko) Télécharger le fichier
hal-00935976 , version 1 (30-01-2014)
Paternité
  • HAL Id : hal-00935976 , version 1
Gonzalo Contreras, Alessio Figalli, Ludovic Rifford. Generic hyperbolicity of Aubry sets on surfaces. Inventiones Mathematicae, 2015, 200 (1). ⟨hal-00935976⟩
476 Consultations
317 Téléchargements
