Supporting the Design and Fabrication of Physical Visualizations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Saiganesh Swaminathan
  • Fonction : Auteur
  • PersonId : 951532
Yvonne Jansen
Pierre Dragicevic
Lora Oehlberg
  • Fonction : Auteur
  • PersonId : 951534
Jean-Daniel Fekete
Physical visualizations come in increasingly diverse forms, and are used in domains including art and entertainment, business analytics, and scientific research. However, creating physical visualizations requires laborious craftsmanship and demands expertise in both data visualization and digital fabrication. We present three case studies that illustrate limitations of current visualization fabrication workflows. We then present MakerVis, a prototype tool that integrates the entire process of creating physical visualizations, from data filtering to physical fabrication. Design sessions with three end users demonstrate how tools such as MakerVis can dramatically lower the barriers to producing physical visualizations. Observations and interviews from these sessions highlighted future research areas, including customization support, using material properties to represent data variables, and allowing the reuse of physical data objects in new visualizations.
Supporting_the_Design_and_Fabrication_of_Physical_Visualizations.pdf (13.57 Mo) Télécharger le fichier
Format : Figure, Image
hal-00935978 , version 1 (20-04-2014)
Saiganesh Swaminathan, Conglei Shi, Yvonne Jansen, Pierre Dragicevic, Lora Oehlberg, et al.. Supporting the Design and Fabrication of Physical Visualizations. Proceedings of the 2014 Annual Conference on Human Factors in Computing Systems (CHI 2014), ACM, Apr 2014, Toronto, ON, Canada. pp.3845--3854, ⟨10.1145/2556288.2557310⟩. ⟨hal-00935978⟩
707 Consultations
1175 Téléchargements
