Positivity and lower bounds for the density of Wiener functionals - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Potential Analysis Année : 2013
We consider a functional on the Wiener space which is smooth and not degenerated in Malliavin sense and we give a criterion for the strict positivity of the density, that we can use to state lower bounds as well. The results are based on the representation of the density in terms of the Riesz transform introduced in Malliavin and Thalmaier [17] and on the estimates of the Riesz transform given in Bally and Caramellino [3]
positivity_30042012.pdf (194.78 Ko) Télécharger le fichier
hal-00936148 , version 1 (04-02-2014)
Vlad Bally, Lucia Caramellino. Positivity and lower bounds for the density of Wiener functionals. Potential Analysis, 2013, 39 (2), pp.141-168. ⟨10.1007/s11118-012-9324-7⟩. ⟨hal-00936148⟩
377 Consultations
159 Téléchargements
