The role of the singing acoustic cues in the perception of broad affect dimensions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
This experiment investigated the role of acoustic correlates of the singing voice in the perception of broad affect dimensions using the two-dimensional model of affect. The dataset consisted of vocal and glottal recordings of a sung vowel interpreted in different singing expressions. Listeners were asked to rate the sounds according to four perceived affect dimensions. A cross-tabulation was done between the singing expressions and affect judgments. A one-way ANOVA was performed for 11 acoustic cues with the affect ratings. It was found that the singing power ratio (SPR), mean intensity, brightness, mean pitch, jitter, shimmer, mean harmonic-to-noise ratio (HNR), and mean autocorrelation discriminate broad affect dimensions. Principal component analysis (PCA) was performed on the acoustic correlates. Two components were retained that explained 78.1% of the total variance of vocal cues and 73.5% of that of the glottal cues.
Son [cs.SD]
Pauline_Mouawad_cmmr2013_submission_118.pdf (210.67 Ko) Télécharger le fichier
hal-00936752 , version 1 (27-01-2014)
  • HAL Id : hal-00936752 , version 1
Pauline Mouawad, Myriam Desainte-Catherine, Anne Gégout-Petit, Catherine Semal. The role of the singing acoustic cues in the perception of broad affect dimensions. The 10th International Symposium on Computer Music Multidisciplinary Research (CMMR 2013), Oct 2013, Marseille, France. pp.98. ⟨hal-00936752⟩
282 Consultations
220 Téléchargements
