A decoding algorithm for CSS codes using the X/Z correlations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2014
Nicolas Delfosse
  • Fonction : Auteur
  • PersonId : 951625
We propose a simple decoding algorithm for CSS codes taking into account the correlations between the X part and the Z part of the error. Applying this idea to surface codes, we derive an improved version of the perfect matching decoding algorithm which uses these X/Z correlations.
Delfosse_Tillich_correlations.pdf (388.83 Ko) Télécharger le fichier
hal-00937128 , version 1 (27-01-2014)
  • HAL Id : hal-00937128 , version 1
Nicolas Delfosse, Jean-Pierre Tillich. A decoding algorithm for CSS codes using the X/Z correlations. 2014. ⟨hal-00937128⟩
Collections
INRIA INRIA2
155 Consultations
427 Téléchargements
