Secure Distributed Programming with Value-Dependent Types
Distributed applications are difficult to program reliably and securely. Dependently typed functional languages promise to prevent broad classes of errors and vulnerabilities, and to enable program ver- ification to proceed side-by-side with development. However, as recursion, effects, and rich libraries are added, using types to reason about programs, specifications, and proofs becomes challenging.
We present F⋆, a full-fledged design and implementation of a new dependently typed language for secure distributed programming. Our language provides arbitrary recursion while maintaining a logically consistent core; it enables modular reasoning about state and other effects using affine types; and it supports proofs of refinement properties using a mixture of cryptographic evidence and logical proof terms. The key mechanism is a new kind system that tracks several sub-languages within F⋆ and controls their interaction. F⋆ subsumes two previous languages, F7 and Fine. We prove type soundness (with proofs mechanized in Coq) and logical consistency for F⋆.
We have implemented a compiler that translates F⋆ to .NET bytecode, based on a prototype for Fine. F⋆ provides access to libraries for concurrency, networking, cryptography, and interoperability with C#, F#, and the other .NET languages. The compiler produces verifiable binaries with 60% code size overhead for proofs and types, as much as a 45x improvement over the Fine compiler, while still enabling efficient bytecode verification.
We have programmed and verified nearly 50,000 lines of F⋆ including new schemes for multi- party sessions; a zero-knowledge privacy-preserving payment protocol; a provenance-aware curated database; a suite of web-browser extensions verified for authorization properties; a cloud-hosted multi-tier web application with a verified reference monitor; the core F⋆ typechecker itself; and programs translated to F⋆ from other languages such as F7 and JavaScript.
secure-distributed-programming-with-value-dependent-types-jfp-1.pdf (493.7 Ko)
Télécharger le fichier
