Mean Reversion with a Variance Threshold - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Starting from a multivariate data set, we study several techniques to isolate affine combinations of the variables with a maximum amount of mean reversion, while constraining the variance to be larger than a given threshold. We show that many of the optimization problems arising in this context can be solved exactly using semidefinite programming and some variant of the S-lemma. In finance, these methods are used to isolate statistical arbitrage opportunities, i.e. mean reverting portfolios with enough variance to overcome market friction. In a more general setting, mean reversion and its generalizations are also used as a proxy for stationarity, while variance simply measures signal strength.
cointstat_final_letter.pdf (231.35 Ko) Télécharger le fichier
hal-00939566 , version 1 (30-01-2014)
  • HAL Id : hal-00939566 , version 1
Marco Cuturi, Alexandre d'Aspremont. Mean Reversion with a Variance Threshold. International Conference on Machine Learning, Jun 2013, United States. pp.271-279. ⟨hal-00939566⟩
255 Consultations
1232 Téléchargements
