The level set method for the two-sided max-plus eigenproblem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Event Dynamic Systems Année : 2013
We consider the max-plus analogue of the eigenproblem for matrix pencils Ax=lambda Bx. We show that the spectrum of (A,B) (i.e., the set of possible values of lambda), which is a finite union of intervals, can be computed in pseudo-polynomial number of operations, by a (pseudo-polynomial) number of calls to an oracle that computes the value of a mean payoff game. The proof relies on the introduction of a spectral function, which we interpret in terms of the least Chebyshev distance between Ax and lambda Bx. The spectrum is obtained as the zero level set of this function.
hal-00940791 , version 1 (02-02-2014)
Stephane Gaubert, Sergei Sergeev. The level set method for the two-sided max-plus eigenproblem. Discrete Event Dynamic Systems, 2013, 23 (2), pp.105-134. ⟨10.1007/s10626-012-0137-z⟩. ⟨hal-00940791⟩
258 Consultations
0 Téléchargements
