Low-rank numerical approximations for high-dimensional Lindblad equations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Physical Review A : Atomic, molecular, and optical physics [1990-2015] Année : 2013
A systematic numerical approach to approximate high-dimensional Lindblad equations is described. It is based on a deterministic rank m approximation of the density operator, the rank m being the only parameter to adjust. From a known initial density operator, this rank m approximation gives at each time step an estimate of its largest m eigenvalues with their associated eigenvectors. A numerical integration scheme is also proposed. Its numerical efficiency in the case of a rank m=12 approximation is demonstrated for oscillation revivals of 50 atoms interacting resonantly with a slightly damped coherent quantized field of 200 photons.
hal-00941530 , version 1 (04-02-2014)
Claude Le Bris, Pierre Rouchon. Low-rank numerical approximations for high-dimensional Lindblad equations. Physical Review A : Atomic, molecular, and optical physics [1990-2015], 2013, 87 (2), pp.022125. ⟨10.1103/PhysRevA.87.022125⟩. ⟨hal-00941530⟩
280 Consultations
0 Téléchargements
