Economic growth and the transition from non-renewable to renewable energy - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Environment and Development Economics Année : 2013
The paper considers the transition of an economy from non-renewable to renewable energy. We set up a canonical growth model with damages in the household's welfare function and two energy sources - non-renewable and renewable energy. To produce renewable energy a capital stock must be built up. A socially optimal solution is considered that takes into account the negative externality from the non-renewable energy. We also study how the optimal solution can be mimicked in a market economy by policies using subsidies and tax rates. To solve the model numerically, we use Nonlinear Model Predictive Control. We study when a transition to renewable energy takes place and whether it occurs before the non-renewable resource is exhausted. In addition, we analyze the impact of the initial values of the non-renewable resource and of the capital stock on the time of paths of the variables.
SSRN-id2098707.pdf (289.14 Ko) Télécharger le fichier
hal-00944277 , version 1 (10-02-2014)
Alfred Greiner, Lars Grüne, Willi Semmler. Economic growth and the transition from non-renewable to renewable energy. Environment and Development Economics, 2013, 34 p. ⟨10.1017/S1355770X13000491⟩. ⟨hal-00944277⟩
Collections
SADCO TDS-MACS
105 Consultations
1831 Téléchargements
