Memory-aware list scheduling for hybrid platforms - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2014
This report provides memory-aware heuristics to schedule tasks graphs onto heterogeneous resources, such as a dual-memory cluster equipped with multicores and a dedicated accelerator (FPGA or GPU). Each task has a different processing time for either resource. The optimization objective is to schedule the graph so as to minimize execution time, given the available memory for each resource type. In addition to ordering the tasks, we must also decide on which resource to execute them, given their computation requirement and the memory currently available on each resource. The major contributions of this report are twofold: (i) the derivation of an intricate integer linear program formulation for this scheduling problem; and (ii) the design of memory-aware heuristics, which outperform the reference heuristics HEFT and MinMin on a wide variety of problem instances. The absolute performance of these heuristics is assessed for small-size graphs, with up to 30 tasks, thanks to the linear program.
rr8461.pdf (2.82 Mo) Télécharger le fichier
hal-00944336 , version 1 (13-02-2014)
  • HAL Id : hal-00944336 , version 1
Julien Herrmann, Loris Marchal, Yves Robert. Memory-aware list scheduling for hybrid platforms. [Research Report] RR-8461, INRIA. 2014, pp.30. ⟨hal-00944336⟩
213 Consultations
258 Téléchargements
