CMOS RF down-conversion mixer design for low-power wireless communications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Ubiquity Année : 2008
This paper aims to study the design of a low-power single-balanced mixer for downconversion in wireless RF receivers. The proposed circuit is designed to work at a radiofrequency of 1.9 GHz using CMOS 0.18 !m technology. The obtained results show a conversion gain equal to 7 dB and low power consumption of 3.86 mW at 1.8.V supply voltage. The single side band noise figure performance was founded to be 8.dB. These results show a good potential of this CMOS mixer and justify its use for low-power wireless communications.
ACM_Ubiquity.pdf (377.41 Ko) Télécharger le fichier
hal-00947369 , version 1 (15-02-2014)
  • HAL Id : hal-00947369 , version 1
Khalid Faitah, Ahmed El Oualkadi, Abdellah Ait Ouhaman. CMOS RF down-conversion mixer design for low-power wireless communications. ACM Ubiquity, 2008, 9 (24). ⟨hal-00947369⟩
114 Consultations
1264 Téléchargements
