Reconciling Web service failing interactions. Toward an approach based on automatic generation of mediators - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
Interactions between Web services are based on interfaces which describe Web services on both structural and behavioural perspectives. It can happen that the interface provided by a service does no longer match (for instance, because of an evolution) the interface required by its partners. In this situation, and until the required interfaces are fixed, interactions cannot succeed. To address this issue, and focusing on the behavioural part of interfaces, we propose an approach based on a mediator, automatically generated, which aims to seamlessly resolve incompatibilities during service interactions.
isws07_aitbachir.pdf (122.03 Ko) Télécharger le fichier
hal-00953884 , version 1 (11-04-2014)
  • HAL Id : hal-00953884 , version 1
Ali Ait-Bachir, Marie-Christine Fauvet. Reconciling Web service failing interactions. Toward an approach based on automatic generation of mediators. 16th IEEE International Workshops on Enabling Technologies: Infrastructures for Collaborative Enterprises (WETICE), 2007, Paris, France. pp.327--332. ⟨hal-00953884⟩
137 Consultations
57 Téléchargements
