Computing nilpotent quotients in finitely presented Lie rings - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 1997
A nilpotent quotient algorithm for finitely presented Lie rings over \textbfZ (and \textbfQ) is described. The paper studies the graded and non-graded cases separately. The algorithm computes the so-called nilpotent presentation for a finitely presented, nilpotent Lie ring. A nilpotent presentation consists of generators for the abelian group and the products expressed as linear combinations for pairs formed by generators. Using that presentation the word problem is decidable in L. Provided that the Lie ring L is graded, it is possible to determine the canonical presentation for a lower central factor of L. Complexity is studied and it is shown that optimising the presentation is NP-hard. Computational details are provided with examples, timing and some structure theorems obtained from computations. Implementation in C and GAP interface are available.
dm010101.pdf (86.76 Ko) Télécharger le fichier
hal-00955687 , version 1 (05-03-2014)
Csaba Schneider. Computing nilpotent quotients in finitely presented Lie rings. Discrete Mathematics and Theoretical Computer Science, 1997, Vol. 1, pp.1-16. ⟨10.46298/dmtcs.234⟩. ⟨hal-00955687⟩
Collections
TDS-MACS
63 Consultations
806 Téléchargements
