On the bialgebra of functional graphs and differential algebras - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Discrete Mathematics and Theoretical Computer Science Année : 1997
We develop the bialgebraic structure based on the set of functional graphs, which generalize the case of the forests of rooted trees. We use noncommutative polynomials as generating monomials of the functional graphs, and we introduce circular and arborescent brackets in accordance with the decomposition in connected components of the graph of a mapping of \1, 2, \ldots, n\ in itself as in the frame of the discrete dynamical systems. We give applications fordifferential algebras and algebras of differential operators.
dm010114.pdf (103.2 Ko) Télécharger le fichier
hal-00955700 , version 1 (05-03-2014)
Maurice Ginocchio. On the bialgebra of functional graphs and differential algebras. Discrete Mathematics and Theoretical Computer Science, 1997, Vol. 1, pp.229-237. ⟨10.46298/dmtcs.244⟩. ⟨hal-00955700⟩
59 Consultations
902 Téléchargements
