Landau damping in Sobolev spaces for the Vlasov-HMF model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Archive for Rational Mechanics and Analysis Année : 2016
We consider the Vlasov-HMF (Hamiltonian Mean-Field) model. We consider solutions starting in a small Sobolev neighborhood of a spatially homogeneous state satisfying a linearized stability criterion (Penrose criterion). We prove that these solutions exhibit a scattering behavior to a modified state, which implies a nonlinear Landau damping effect with polynomial rate of damping.
HMFbisfinal.pdf (188.87 Ko) Télécharger le fichier
hal-00956595 , version 1 (06-03-2014)
hal-00956595 , version 2 (17-04-2014)
Erwan Faou, Frédéric Rousset. Landau damping in Sobolev spaces for the Vlasov-HMF model. Archive for Rational Mechanics and Analysis, 2016, 219 (2), pp.887-902. ⟨10.1007/s00205-015-0911-9⟩. ⟨hal-00956595v2⟩
333 Consultations
303 Téléchargements
